hub&steering knuckle issue..can't remove
The other side is fine & this caliber appears to be fine.I was able to get a steering knuckle from the boneyard they already had it pulled.I then got the new hub came home& none of my sockets in my axle socket set fit turns out its 43mm I went to my buddys shop & the closest thing he has is a 1& 3/4 well on the new hub it'll fit between the lip down the middle but on the old one it won't fit in there.My only thought is to cut the studs & lip off.Anybody else have an idea?None of the parts stores has any other sockets
You can't get the axle nut off? If so, I had a problem with one of mine when I changed hub assembly's. Nothing would work, lotsa leverage, impact wrench, even heated it up with oxy-acetylene torch. Finally got it by popping the wheel studs out of the rotor, there's one place you drive them out without hitting anything. Cut half the lip off with a 7" angle grinder so I could get a straight shot at the nut with a cold chisel. Got it. It was junk anyway. Obviously you'll need a new nut if you have to do something like that.
If you think you can get it once you get the socket on it, you could pop all of the studs out and cut all of the lip off. Just have to be careful not to mess up the nut in the process.
So the 1&3/4 won't work?I need a little more info the fella @ the salvage yard who pulled the knuckle said "its easy undo the 3 bolts off of the back of hub & pop off pittman arm &the axle will slide right out" or something close to that But the book says you have to pull the shock,the coil,drop the drive shaft & a whole bunch of stuff.Now is this true?What's the easiest way to remove the hub assembly & steering knuckle.SOMEONE PLEASE HELP.I'm gonna go look up some info via the sites search feature If I find it out Ill let you guys know.
Remove the 3 spindle bolts from the back after you remove the caliper and you can remove the hub assembly and axle as one unit.
Disconnect the tie rod from the knuckle and remove the ball joints and tap the knuckle out with a hammer. If you have ABS, you'll have to unplug that first also.
You don't have to remove shocks or springs or anything else to get the hub assembly and knuckle off.
If your not replacing the stub shaft as well, you're gonna have to get that axle nut off. Be easier to do while it's still on the truck.
Trending Topics
