I have a 99 ram 2wd 5.2 with a 46re.
I am having a transmission problem. it shifts ok into all gears. if I get onto the power it just reves up and slowly picks up speed. it just started doing this before this it picked up speed quick.
Procedure is in the FSM you can download from the FAQ/DIY section. Front band is adjusted on outside of trans., the other one, you have to drop the trans. pan. Easy to do really.
ok that trans is shot it only has 1st and revere if it goes into 2 it just slips. I adjusted bands and no help. so I am going to have it rebuilt is there any thing I should have them put in it to help fix the 46re problems
Better torque converter.
Sonnax Sure Cure. (shift kit, sorta.)
Additional cooler. (if you don't have the towing/heavy duty package, and already have one.)
Borg warner heavy duty governor pressure solenoid.
Additional clutches/steels.
Heavy duty planetaries. (fix, and six pinion.)
Etc.
There is a nice list on page six of MonteC's trans thread.
