Start then quickly stall.....
2003 Dodge Ram 1500 4x4
5.9l
So A few months ago i fixed my plenum/changed the dist cap and rotor and put everything back together. I ran seafoam and everything has been running smooth. Up until last week when it would just start then stall. At first I though it was the battery but then i realized the battery would turn the engine but the engine would just struggle to start.
My first question is: would a clogged cat cause this problem?
So far there have been no codes have been thrown up and I figured if it was a sensor, maybe some codes would appear. But then again, I cant seem to get the engine to run long enough. I have searched and only found limited results for other vehicles with no answer on what the fix was.
5.9l
So apparently it is not the cat. Just disconnected it before the cat and it still had the same trouble. However, this time I let the engine rev a little higher on the start up and after about 20-30 seconds, the truck runs fine. I don't know if it was because i only drive it every so often and its been like two weeks since i have driven it last? It doesn't get too cold here (its 65 degrees right now).
Either way how hard is it to change the cam position sensor and everything else that might be associated. I think gthe fuel pump is fine cause i can here it whine when the truck stalls.
Oh I can clean this? I was just going to get a new one. I think they are $34 at the local oreillys. Just wipe it down with a rag?
Trending Topics
My guess is that the motor is sluggish in responding and is toast but try to clean anyway.
re-use the trottle body gasket or spend ~$4 for a new one? I remember when I did my plenum someone said the best way to check was to take the throttle body off and peek inside the keg but I would have to spend 4 bucks on a new gasket. The old gasket seems fine but I dont know if they are a one time use thing.
