Grinding sound at 70+mph
Old May 29, 2014 | 02:06 PM
  #61
merc225hp's Avatar
merc225hp
Long shot but have you checked all the brake calipers sliding pins? Are the caliper's floating/sliding as they should? A dragging brake will cause all kinds of handling issues and weird noises.
GL
Old May 29, 2014 | 02:58 PM
  #62
Ham Bone's Avatar
Ham Bone
GL
I've checked the front but I myself forget I have rear disc. They are new. calipers and pads. But I will check them later. And 're check the front when I put these new rottors and pads on.
Old Jun 2, 2014 | 05:07 PM
  #63
corbo1962's Avatar
corbo1962
Did the new pads and rotors make a difference in the grinding noise
Old Jun 2, 2014 | 05:48 PM
  #64
Ham Bone's Avatar
Ham Bone
Haven't been up to speed to yet. Will know tomorrow morning on way to work and update the thread.
Old Jun 5, 2014 | 06:42 PM
  #65
Ham Bone's Avatar
Ham Bone
Ok update time.
Brakes didn't help. But I have a really really great pedal now.
Installed my 241ld today. Heard of a couple other guys with similiar symptoms and they had a bad output bearing on the t case. So I installed the 241 and,
It changed the sound. It's now more..... Dull??? Is h ow i could describe it there? Muffled? It's just different.
Sooooo what could that mean ?
Old Jun 5, 2014 | 11:35 PM
  #66
You did remember to fill the t-case, right?
Old Jun 6, 2014 | 01:11 AM
  #67
Wh1t3NuKle's Avatar
Wh1t3NuKle
Dang HB...quite the issue going on.
So you changed the tcase out. That changed the sound. I don't remember in your thread if it was covered, but what about the pinion bearing of the swapped in rear end? You installed it as-is if I recall. It would have an impact on the sound based on your changes. Just another thought off the top of my head.
Old Jun 6, 2014 | 02:14 AM
  #68
corbo1962's Avatar
corbo1962
Ya HB, this is getting ridiculous, but your already there...right! WK could be on to something there with that bearing. I had mentioned the pinion angle earlier and a bad pinion bearing could give that problem. The transfer case swap changing the noise tells me it has to do with something that is linked up to the T-Case.
Old Jun 6, 2014 | 06:56 AM
  #69
Ham Bone's Avatar
Ham Bone
Yea just installed as is. I guess I'll work on the pinion bearing next. Haven't done that one before.
I did initally think that. But I thought it would be a more obvious, chattering sound.
Only thing is Idk how the pinion bearing could effect the noise when I change to the right lane at speed?
Old Jun 6, 2014 | 07:38 AM
  #70
corbo1962's Avatar
corbo1962
Yes that is puzzling, but everything is connected and I guess the side to side motion could impact the pinion through the rear wheels
