Engine Ruff Idle Wont Go Away
Old Sep 21, 2014 | 02:38 PM
wlatour's Avatar
wlatour
Default Engine Ruff Idle Wont Go Away
2001 Dodge Ram 2500 5.9L Gas 360. MY new issue is the ruff idle. Changed plugs, Wires, Cap, Rotor, Pickup Coil, Lower Coil. Then I changed Idle air, Mass Flow, Throttle position, two fuel injectors that I was getting codes on. Had pressure test done and they are fine. My dealer said I had a bad ECM Control Module? Any Thoughts??
Old Sep 21, 2014 | 02:57 PM
Fixed the plenum? How did the old plugs look? Done a compression test? Change the crank sensor? Does it do it right away, or, only after running for a few minutes?
Old Sep 22, 2014 | 02:30 PM
It's Me Patt's Avatar
It's Me Patt
might want to add a signature
Old Sep 22, 2014 | 07:35 PM
wlatour's Avatar
wlatour
Default Parts Changed
Never touched the Plenum? I do have a loud air leak when I first start it? It's coming from back of the Throttle Body. Plugs were ok but had lots of gas smell to them? Never change the crank sensor (that's only if you have start issues not running) The problem starts right away. Engine shakes. If I rev the engine high (3-4 1000rpm) it will pulse up and down. When driving it runs fine...
Old Sep 22, 2014 | 09:24 PM
Erm, the crank sensor is a critical component, and is used by the PCM to determine ignition timing. The sensor in the distributor is for cam position, and is used to determine which injector to fire........ A failing crank sensor would give you the symptoms you are seeing. Especially the erratic running at high RPM.
Is the check engine lite flashing when it does that? Is it on at all?
Old Sep 22, 2014 | 09:30 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Fixed the plenum?
Ding!
Meh, maybe the distributor is worn out? See if that little metal half-moon pickup is loose on the shaft. The one under the pickup plate
Old Sep 27, 2014 | 07:37 AM
wlatour's Avatar
wlatour
Well Changed out the Crank Sensor (1 Hour) and still no difference on engine running and skipping. My check engine light does work. Last week I had a vacuum leak and I had to replace the Filler pipe at rear. My next guess is the ECM Module? I have changed just about everything. Thanks for all the tips....
Old Sep 27, 2014 | 07:41 AM
wlatour's Avatar
wlatour
Just found a New ECM Module for $250.00 http://www.solopcms.com/2001-dodge-p...-gas-only.html I'm going to order this today. My question on this part? Does it need to be programed by Dodge? Thanks
Old Sep 27, 2014 | 08:39 AM
Needs to be programmed for your vin. The selling company 'might' do that before shipping, but, don't hold your breath. Any shop with a good scanner should be able to do it for ya. (for a fee, of course.....)
But, simply throwing parts at it until you find a 'fix' can get REAL expensive. Also, brand of parts DOES make a difference here. Fair percentage of folks have had poor results from cheap, aftermarket parts, in critical areas. (and the crank sensor is most certainly one of those.)
Also, if you haven't fixed the plenum yet, there is a very good chance that NOTHING you do will make the least bit of difference. Need to solve known problems before you go exploring for other possibilities.
Old Sep 28, 2014 | 08:00 AM
wlatour's Avatar
wlatour
So Far I have replaced all parts with Mopar Parts from dodge. Fixing the Plenum is on my list of do's... Bigger Issues? I just went for a road test last night and now I have an issue with Reverse again. Very skipping trying to back up? It was fine after adjustments. I'm now at the point to maybe retire the truck..(Money Pit)...Thanks
