Lifters on a 360.
Trending Topics
That's a lot of work just to replace a set of lifters. If you commit to that, you'd also want to commit to a pretty comprehensive "refresh"... At least include the plenum gasket job and a new timing chain set.
I, too, am curious why you are ready to retire your current lifters. If they are a little noisy, there's other things I'd try first before signing up for tearing out the old ones.
Lifter question
OK then I should replace just the Lifters and not the heads. My question was which way is cheaper so I guessing the lifter replacement is the cheapest way to go. As far as why I should replace the lifters is they make a racket especially on acceleration. so replace the lifters it will be.
Erm, are you SURE it's your lifters you are hearing, and not spark knock? (sounds VERY similar.) I would bet real money your plenum is blown, and you are actually hearing the spark knock... would be a real bummer to spend that kind of money, and NOT fix the problem.
What does your oil pressure look like?
