Warmer weather causing long crank?
#21
i replaced the fuel pump with a airtex unit close to a year ago.
the problem is, i dont have the know how to diagnose this myself and i also dont want a shop to play doctor on it and charge the hell out of me.
i can say that this issue started after i put that airtex pump in and got worse when i put a new purge solenoid, blew the lines out and also put a new vapor canister on too.
maybe this additional info will help you guys point me in the right direction.
#22
#23
#30
delphi it is. cant be worse than the airtex.
so based off the information ive given, you think its safe to go head and replace the pump? or should i take it to a shop and tell them specifically to check the fuel pump?
id rather not spend money i dont need to spend. i know however without testing its hard to say for sure.
