tires and rims
Old 05-22-2015, 08:18 PM
zildjian3707's Avatar
zildjian3707
zildjian3707 is offline
Default tires and rims
got a rippen deal on a set of 35 bfg kos. now on to rims. Will these rims fit my 97
http://www.4wheelparts.com/Wheels/Se..._pn=PCW97-5185
Old 05-22-2015, 08:38 PM
peterbilt201's Avatar
peterbilt201
peterbilt201 is offline
im interested to cause i like those rims.
Old 05-23-2015, 10:39 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,269 Likes on 3,016 Posts
Might be some clearance issues around the brake caliper, and/or the tie rod..... they only have 3.75 backspacing, and are 10 inches wide though.... so, my guess is, you are going to get some rubbing on turns at the front and back of the wheel opening...... Don't know if you can go to more backspacing to alleviate some of that.......
Old 05-23-2015, 11:29 PM
zildjian3707
ive got spacers too
Old 05-24-2015, 09:53 AM
Spacers will only make the problem worse, not better.
Old 05-24-2015, 08:56 PM
zildjian3707
done a little reserach, seems no one has a problem with clearance issues until the late 2nd gens 99+ cause of the upgraded calipers, a lot of people seem to run 15s since the tires are way cheap. will see what happens
Old 05-25-2015, 12:14 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
Set of 4 sore thumbs never hurt anyone, right?
Bad idea
Old 05-25-2015, 04:23 PM
zildjian3707
Old 05-28-2015, 09:52 AM
Moparite's Avatar
Moparite
Moparite is offline
I think you will have issues fitting 35's on a stock 1500(no lift) if that's what you have(no info). I think 33's are the limit on stock lift.
Old 05-28-2015, 06:47 PM
zildjian3707
ive got 5.5 lift
Quick Reply: tires and rims
