Hey everyone been having a problem lately with my truck. It only does it sometimes and just started withing last few months. Sometimes its first thing in the morning, sometimes mid day. Sitting for awhile or shortly after shut off so the problem is intermittent. Truck just cranks and cranks until I pump the gas. What causes this? Fuel pump, injectors, sensor? Thanks for a direction.
No codes and I dont always pay attention to listen to fuel pump but if I do I can hear it. Also my fuel gauge quit working, stuck on empty all the time. Not sure if its connected to the crank issue
Fuel sender is bad. It doesn't effect fuel pressure. I drove around two years with out one. I just would fill the tank and refill it when it got to the right mileage. I guess you are doing the same?
Yeah I refill about 225-240 mile mark. So tps may be dirty? How should I go about checking the sensor and iac motor? If it was bad wouldnt it do it all the time?
