Misfire monitor
Old Jan 10, 2016 | 02:42 PM
  #31
dapepper9's Avatar
dapepper9
injectors changed? Stock new or "refurbished" from ebay?
Old Jan 10, 2016 | 02:56 PM
  #32
360_magnum's Avatar
360_magnum
Brand new, I don't trust ebay with parts. I got them from auto zone if I remember correctly
Old Jan 10, 2016 | 02:57 PM
  #33
dapepper9's Avatar
dapepper9
Same p/n as the ones you pulled?
Old Jan 10, 2016 | 02:58 PM
  #34
360_magnum's Avatar
360_magnum
Ya I think so
Old Jan 10, 2016 | 02:59 PM
  #35
360_magnum's Avatar
360_magnum
I have thought about putting a couple of my old ones in on the cylinders just for kicks to see what happens.
Old Jan 10, 2016 | 04:37 PM
  #36
Ohm test your injectors, and see what you get. Should be around 12 ohms, as I recall.
Old Feb 17, 2016 | 05:04 PM
  #37
360_magnum's Avatar
360_magnum
Ok the injectors tested good. They aren't all exactly the same but pretty close. Where can I go from here?
Old Feb 18, 2016 | 09:59 AM
  #38
Give us a reminder of what all you have done to troubleshoot this.... I don't want to have to read back thru the whole thread.
Old Feb 19, 2016 | 12:49 AM
  #39
360_magnum's Avatar
360_magnum
Ok here's everything to the best of my memory.
Crank sensor, cam sensor, both oxygen sensors, cap and rotor plugs and wires, all 8 injectors, all gaskets I could get to, throttle position sensor, pcv, IAC.
Old Feb 19, 2016 | 09:32 AM
  #40
Think it's time for a compression/leakdown test.
