Broken transfer case need help..
If there is no vac switch, then this tcase is not for a Dodge. I should have pictures here to show where on the tcase.
https://dodgeforum.com/forum/2nd-gen...ml#post3078431
Don't buy it....I'm thinking.
Just a normal day of light abuse. Long story shory I heard a clunk going from 4HI to 2HI didnt think much of it... Shortly after i when over a small curb (going slow) and it she split. There has been a massive vibration in 4HI and slight vibration in 2HI. I wish i new why it broke so i cant avoid this in the future. Thanks for everybodys help.
Last edited by iconracing; 12-11-2015 at 11:36 PM. Reason: Drunk typing forgot proper grammer
If you haven't yet, pull the tail shaft housing to get a look at the infamous snap ring. If it's broken, it's the culprit -- they're known for splattering cases when they go. The transfer case saver is darn good insurance for fifty bucks and an hour of DIY installation.
The vibration you described would be consistent with a broken snap ring. There usually aren't any symptoms at all when the snap ring first goes, but over time the shaft gets progressively wobblier, and eventually the case just can't stand up to the assault any longer. The vibration hammers and cracks the case, and the long lever that is the rear drive line just pries the thing open, usually with the help of a sharp bump or an exuberant mash of the gas pedal.
