wiring questions
Old Dec 11, 2015 | 05:09 PM
jeepzilla's Avatar
jeepzilla
Default wiring questions
I have seen on here that one of the guys did the big block swap to his 2gen, I have a few wiring questions for him. I cant seem to locate his name or thread.
Old Dec 12, 2015 | 09:31 AM
I know a few folks have thought about doing a big block swap, but, I am not aware of any threads on here (since I have been here...) where we see one start to finish, that actually GETS finished.
Folks have done it...... Just no one here that I am aware of.
Here is one thread. I am not really coming up with any others where they actually DO the swap.
Old Dec 12, 2015 | 11:42 AM
jeepzilla's Avatar
jeepzilla
Default Big block swap
Ok, i guess i will be the first one..
Old Dec 12, 2015 | 12:42 PM
jeepzilla's Avatar
jeepzilla
Default Back to wiring,
So i guess the question would be does any one already know what wires can be used to get the engine running?
Old Dec 12, 2015 | 05:11 PM
Basically, it's going to be: Strip out most of the stock wiring, and put in your own. What year is the truck you want to drop the motor into?
Old Dec 12, 2015 | 06:56 PM
jeepzilla's Avatar
jeepzilla
She is a 1998 4wd
Have a built 440 pushing around 480 hp
Tremec T-56 trans
Divorced transfer case to keep 4wd
Old Dec 12, 2015 | 07:04 PM
jeepzilla's Avatar
jeepzilla
I will get more pictures of the engine in the near future
Old Dec 12, 2015 | 07:13 PM
That's gonna be fun.... In more than one sense of the word..... Chances are good, all of your instruments are driven by the PCM, thru the central timer module. It's entirely possible NONE of your gauges will work with the 440.......
Old Dec 12, 2015 | 09:32 PM
jeepzilla's Avatar
jeepzilla
I have been going through and tracing each guage to see what does not go through the pcm. If the cluster doesnt work i was thinking of replacing the individual guage.
Old Dec 12, 2015 | 09:46 PM
I *think* oil pressure is the only one that doesn't go thru the PCM. (PCM really doesn't care about oil pressure..... which I find kinda odd.....) Everything else pretty much goes thru the CTM. Do you have a copy of the service manual yet? If not, grab one here.
