Tranny fluid question
Old Feb 3, 2016 | 12:21 PM
Billkerr74's Avatar
Billkerr74
Default Tranny fluid question
I have a 2000 dodge ram 4x4 and im wanting to put the B&M trick shift fuild in it. Should i do this or will i prob be facing tranny issues in future?
Old Feb 3, 2016 | 12:22 PM
Why do you want to put that fluid in?
Old Feb 3, 2016 | 12:38 PM
Dodge recommends ONLY ATF +4. Even our resident trans guru (whom me miss dearly) suggested that any other fluids would more than likely leave you with problems.
Old Feb 3, 2016 | 01:50 PM
Billkerr74's Avatar
Billkerr74
I was told it was really good stuff
Old Feb 3, 2016 | 01:51 PM
Billkerr74's Avatar
Billkerr74
Could u tell me the best brand to use?
Old Feb 3, 2016 | 01:59 PM
dapepper9's Avatar
dapepper9
I use Valvoline. +1 to nothing but ATF+4. Dodge trannies are sensitive to things like that
Old Feb 3, 2016 | 02:28 PM
Originally Posted by Billkerr74
U was told it was really good stuff
Who told you that? Really good stuff for what? At any rate, stick with ATF+4.
Old Feb 3, 2016 | 07:18 PM
Erik P's Avatar
Erik P
ATF +4 is all the same. If something is labelled ATF +4 it means it meets all the criteria to be ATF +4. So go buy whatever is on sale and fill 'er up. Like everyone has said, ONLY and nothing else other than ATF +4 should go in your dodge trans...
Old Feb 3, 2016 | 08:57 PM
wyrmrider's Avatar
wyrmrider
you must use atr-4 if you have a lock up converter
If you have put in a non lock up you can use most anything in a tq
but atf4 is a premium synthetic atf- you relly can't do any better
developed the Transgo kit on my truck many years ago
250 thou miles and lots of towing just starting to not shift as chrisp
Old Feb 4, 2016 | 11:07 AM
Moparite's Avatar
Moparite
Back in the day i used B&M trick shift in a 727 trans that already had a shift kit in it. I really did not notice any improvement in shifts/etc like they claim it will improve. I say save your money and improve your hardware if you are looking for improvements.
