Making a plenum plate
Old 02-28-2016, 01:59 AM
UnregisteredUser's Avatar
UnregisteredUser
UnregisteredUser is offline
Originally Posted by Moparite
Well there are plenty of people out there (including me) that will disagree with you.
Not intending to stab too deeply: It's a poor personal choice to know things you haven't put out the effort to learn. It makes life difficult for you and anyone foolish enough to trust you.
Old 02-28-2016, 09:33 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,390 Likes on 3,130 Posts
Well there are plenty of people out there (including me) that will disagree with you. The paper thin piece of steel that was used don't hold up, That's why they leak in the first place. Chrysler had a TSB about it. http://dodgeram.info/tsb/2000/09-05-00.htm Just get a piece of aluminum and use the gasket as a template. You can make one in no time and it's cheaper than what Hughes is selling them for.
Notice that even in the TSB, they replace the gaskets, and the bolts, but do not replace the pan itself.
Old 02-28-2016, 01:06 PM
Snowfan's Avatar
Snowfan
Snowfan is offline
Also to not distract too much from the OP's thread...
This is an original plenum bolt bottomed out in my plenum...
It is proof that insufficient clamping force is what causes the gasket to slip. Shorter bolt clamps tighter without bottoming. Either grind off the unthreaded portion of bolt or get 1/4-20 3/4 bolts. Sorry for any hijack.
Old 02-28-2016, 06:05 PM
stewie01's Avatar
stewie01
stewie01 is offline
Anyone else remember when people just argued whether or not the intake manifold bolts were TTY or not?
Old 02-28-2016, 06:07 PM
evilemokid94's Avatar
evilemokid94
evilemokid94 is offline
your fine, so if I ground down the bolts or replaced them with shorter bolts I could get away with not doing the plenum plate?
Old 02-28-2016, 06:11 PM
UnregisteredUser
If it's not there yet, that photo belongs in the End-all Be-all plenum thread for sure. Not because installing an aluminum plate is a bad thing in and of itself -- if no ancillary harm comes of it the aluminum is as harmlessly pointless as a throttle body spacer, and if a guy wants it he should have it. It's just better for humanity if more of its members have a reality based view of the world.
Ain't no magic in a pickup truck made of rock and stinky goo. It's all perfectly understandable.
Old 02-28-2016, 06:19 PM
Done. Edited the first post, section dealing with the cause. He had it as dissimilar metals. Not the case. (as has been proved several times over the last couple years)
Old 02-28-2016, 07:58 PM
Snowfan's Avatar
Snowfan
Snowfan is offline
Yes. You can grind off most of the unthreaded tip of each bolt and it will work perfectly. For prep, clean both the plenum and steel plate mating surfaces down to bare metal. A scotchbrite wet with wd40 works well.
Wipe lightly but thoroughly with alcohol. Coat completely both sides of a new gasket with a thin layer of Black oil resistant Permatex rtv and install to spec according to the service manual.
I put on a rubber glove and massage the rtv all over the gasket leaving no dry spots but no excess to splooge off into the engine or intake.
Old 02-28-2016, 10:11 PM
UnregisteredUser
Dude, you're what makes the 2nd gen forum what it is.
Old 02-29-2016, 08:35 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
A wretched hive of scum and villainy?
Quick Reply: Making a plenum plate
