Making a plenum plate
Old 09-10-2016, 02:20 PM
Brian in Tucson's Avatar
Brian in Tucson
Brian in Tucson is offline
Originally Posted by must6655
I have a few plenum repair plates , plenumrepairplate.com, 70 bucks includes shipping...
I've bought from this guy, and I've bought from Hughes. The only difference I could see was that Hughes costs more. I used Dorman gasket kits, something Hughes says is a no-no. The gaskets haven't been a problem.
  #32
Old 09-11-2016, 07:36 AM
TarheelDodge's Avatar
TarheelDodge
TarheelDodge is offline
I bought an 1/4" aluminum plate, traced the gasket, trimmed to fit and trimmed the new pan hardware. All less than $60 and some cussing. The peace of mind is worth the headache. Dodge should have made the intake manifold one piece, the idiots. My experience is "new" ain't always better. Good luck, Greg
  #33
Old 09-11-2016, 08:50 AM
Moparite's Avatar
Moparite
Moparite is offline
What he said! I believe i also mentioned making it. 1/4" plate a drill and a jig saw(or band saw it you have one) and some time then you are set. I would buy the fel pro gasket though.
  #34
Old 09-11-2016, 10:33 AM
Brian in Tucson
When I made mine, I found working the aluminum was quite difficult. Which is why I elected to buy one from the guy previously mentioned (for my other engine.) On Ebay. Aluminum has a lower melting point that steel, it gums up saw blades and grinding wheels. As for gaskets, any set will do if you use Permatex copper rtv. Goop the sumbitch in.
  #35
Old 09-11-2016, 08:08 PM
Moparite's Avatar
Moparite
Moparite is offline
You are not supposed to grind aluminum! You can sand it. Use a mixture of kerosene and oil on the saw blade and that will keep it from getting clogged.
  #36
Old 09-17-2016, 05:15 PM
olefart's Avatar
olefart
olefart is offline
local shop cut mine with a plasma torch using my steel one which had blown out the sides between the bolts which mine where short enough just to much expansion differences with the temps running high, climbing up and down the hills they build our roads on out west here, stay in town or flat country you can get away with the steel plate but not if your getting it heated up drive up and down the hills. mine hasn't been on long enough to see if it has solved the problem for me, will know after my trips down south during the winter, from sea level to over 9,000ft can heat your engine up a lot an eye has to be on the temp gauge so it don't get to bad.
Quick Reply: Making a plenum plate
