Building up my 95 dodge ram 2500
#21
Is there any way to to let it code or ride funny I looked there is a plug in the header they must of removed the o2 when they did my exaust, 02 pipe is gone...
#22
![](https://cimg3.ibsrv.net/gimg/dodgeforum.com-vbulletin/640x480/image_1e5afbe7ca158a68d45769d80268f85c10c34c7d.jpg)
A bit ruff needs more elbow grease
![](https://cimg4.ibsrv.net/gimg/dodgeforum.com-vbulletin/2000x1493/image_f2e8018d0ce107e90a1c950bcb25c5c5463f3457.jpg)
![](https://cimg5.ibsrv.net/gimg/dodgeforum.com-vbulletin/2000x1493/image_5343198f533d6ea48bfcb749e1d4aae600ab52be.jpg)
Already had a double chain but it was loose.. When I put the new one on it was much tighter was scared cam was bad
![](https://cimg6.ibsrv.net/gimg/dodgeforum.com-vbulletin/2000x1493/image_b19570ced9d3ff7faa706ee29f02d526a226acd9.jpg)
![](https://cimg7.ibsrv.net/gimg/dodgeforum.com-vbulletin/2000x1493/image_355887188e5a9c9b7d6266cef42c393c1439a27e.jpg)
![](https://cimg8.ibsrv.net/gimg/dodgeforum.com-vbulletin/2000x1493/image_026e4c7401e2ba749986e645f77c03014f9fe2df.jpg)
Bracket pic is for a rough generalization of what it'll look like and sealant pic is where I noticed new timing chain gasket looked kinked :/ didn't notice till I got it all back together
#23
#24
#25
#26
I'm not sure if he welded it or not I need to look if worst comes to worst I can tap it out and install one iv been trying to read up on it do I need the rear one or front and where would it plug in?
#27
Front only on your truck. On the OBDI fellers, they didn't care about cat efficiency. ![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
They make weld-on bungs as well.... so, if you can't get the plug out, that would be another option.
Plug for the O2 sensor will be up on top of the trans, just behind the bellhousing. You can see it, or, you can touch it, but, likely not both at the same time.
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
#28
Plug for the O2 sensor will be up on top of the trans, just behind the bellhousing. You can see it, or, you can touch it, but, likely not both at the same time.![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
#29
#30
