Building up my 95 dodge ram 2500
As the title states I'm building up my old 1995 dodge ram 4x4 with the 360 it's the Dana 44 front 9.25 rear end it is going to be my work/plow/mud truck it's not going to be making little if any long trips it sat for almost 5 years before I was able to afford to get her running right (she was leaking oil) bad oil switch but can now afford it so far I have put in pace setter long tube headers, true duel exhaust 2 1/2 pipe with thrush welded mufflers, and soon a x pipe, distributer cap, rotor, wires plug, water pump, a/c delete, radiator, thermostat, battery, u-joints so she's pretty good mechanically right now I have bought new rims and tires 35x12.5x16.5 my fenders were pretty rusty/rotted but I have a metal fab buddy making me some custom cut out flares bit of rub stock. Now what I'm wondering is the tires are hard (expensive) used and new unless I go with the military 37x12.5x16.5 now I haven't done anything to the suspension yet cause with the plow I know it will way it down and saw if I had v10 springs or maybe coil spacers I plan to cut up the fenders abit any way to get rid of the rust on them on the front end and rear end but then I'll need a lift all the way around to clear the tires at the same time don't want it lifted up to high put strain on the axels from the plow/tire setup so any suggestions I don't care about ride comfort btw just need to keep the fenders off the wheels would be appreciated I plan on keeping this truck a long time so if I gotta spend a bit more it'll take me a while to get but if there is a cheaper but still good alternative that would be awesome thanks
Spark plug in cyl 5 snapped lol got it out btw
Pic before I got stared I drove her out from behind the shed
Distributer was held on with a zip tie screw was snapped
Rotor lol cyl 1 and 4 I believe were swaped on the plug wires mad for some nasty backfire runs great now don't even know how it drove around the yard before lol
New tires exhaust
Btw this is not just a lift question also about motor like what else I should change I forgot to mention earlier I also plan on getting a double timing chain before I do water pump and I also still need to buy the two main radiator hoses I believe mine is leaking I also plan on the kegger mod and throttle body mod in the near future just waiting on fund and for it to get warmer I do not have a garage to work out of just a tarp and it's like 20 degrees right now lol
I should also say future plans before the plow is to cut out rust sand blast pull big dents and rhino line the whole truck and frame if I can or undercoating don't want the salt to eat it away to fast after I finish me and my dad are going for a baja truck look (gives us an excuse to chop her up a bit) and my buddy is going to reinforce the panels we do so they don't get "floppy"
Trending Topics
Cleaned her up alot
Time for the throttle body and intake I broke a screw on the tb :/ and hose up front and question what is the sensor thing on the back of the fuel rail on the right side?
