Need help with 46re transmission
Old Mar 13, 2016 | 07:58 PM
  #21
Moparite's Avatar
Moparite
Gps will tell you.
Old Mar 14, 2016 | 08:55 AM
  #22
Creeves's Avatar
Creeves
But the speedometer and tach being off wouldn't cause it to shift wrong would it.. The pcm is reading the correct idle and speed, it's just the gauges are showing wrong.. Correct?
Old Mar 14, 2016 | 09:01 AM
  #23
Pretty much.
  #24
Creeves's Avatar
Creeves
I should be able to drive around with no gauges at all and it still should shift right because the pcm is getting the data, the gauges just show the data
Old Mar 14, 2016 | 09:25 AM
  #25
Correct.
Old Mar 14, 2016 | 09:48 AM
  #26
Creeves's Avatar
Creeves
Well what else could it be? Any suggestions?
Old Mar 14, 2016 | 10:00 AM
  #27
Verify your instruments are off first. Take it from there.
Old Mar 14, 2016 | 10:29 AM
  #28
Creeves's Avatar
Creeves
I'll see what I can do.. Thanks
Old Apr 21, 2016 | 07:57 PM
  #29
Creeves's Avatar
Creeves
New symptom; 98% of the time after it shifts from 2nd to 3rd gear after it hits 3000 rpm, it will go in 3rd fine then down shift into second for 1 second, then shift back into 3rd and then over drive
Old Apr 21, 2016 | 08:46 PM
  #30
Are you stepping pretty hard on the gas during those times? I live out in the sticks, where speed limits are all over 50mph, and my truck rarely sees even 2500 RPM.....
