parasitic draw and P01765 and P0753 codes
Old Apr 17, 2016 | 09:40 AM
  #31
dbbd1's Avatar
dbbd1
Originally Posted by UnregisteredUser
I'd guess that there's a pulley alignment problem there. Do you see more wear on one outer edge of the belt than on the other? Or, on the underside of the belt, more erosion of one side of the ribs than the other?
I was thinking tensioner. The pulley (bearing) may "feel" okay but what about the spring tension from the tensioner?
Old Apr 17, 2016 | 10:02 AM
  #32
Moparite's Avatar
Moparite
Neither, This problem was on another forum I'm on and you need to take off the glaze on the pulleys. Mine does it too. Take off the serp belt and go over all the pulleys with a wire brush. That should do the trick.
Old Apr 17, 2016 | 11:26 AM
  #33
bunker's Avatar
bunker
Default new
yes its new feels ok doesn't shake or wobble
Old Apr 17, 2016 | 11:28 AM
  #34
bunker's Avatar
bunker
Default sunday morning with a ram
Okay, with that it's clear that your jumper is powering up the transmission solenoid assembly, and that's the cause of the CEL and at least some of your drain.
So now the question is why, technically, you've got to use a jumper instead of a relay. Got a multimeter or at least a test light handy? We need to find out which signal is missing from the socket's relay coil terminals.
Looking at the relay socket from the left (driver's side) of the vehicle, there are three terminals oriented perpendicular to your shoulders, straight toward and straight away from you. Pin 85 is the rightmost, pin 86 the leftmost. When the engine is running we want to see power on pin 86, and ground (more or less zero volts) on pin 85. (Edited to add: You may have to have the engine running and transmission shifted into a drive gear to get the ground signal on pin 85. I'm not certain about this, so if you happen to find that it's always present when the engine is running, or not present until the transmission is shifted into gear, please let me know, and thanks!) If you've got a test lamp, just hang it between those two pins and it should light up when the engine is running and go dark when the engine stops. If a voltmeter, probe those terminals with negative to 85 and positive to 86, and start the engine. You should see something approximating battery voltage appearing there.
But it probably won't. In that case, if all you've got is a test light, hook the alligator clip to the battery positive terminal, probe to pin 85, and then start the engine (and shift into a drive gear, too). If the test lamp illuminates, pin 85's getting the right stuff. Then move the alligator clip to ground, and the probe to pin 86. Again, the lamp should illuminate when the engine runs (and in gear/not in gear doesn't matter for this test). If you're using a voltmeter instead, the first test is positive to battery positive, negative to pin 85, and the second test is positive to pin 86 and negative to chassis ground. In both you'd expect battery voltage or thereabouts to appear.
One of these two tests, though, should fail. If neither does, then grin all the way to the auto parts store because the problem was a failed relay all along.
With the knowledge of which test fails, we can proceed to figure out if it's a broken conductor or a failed driver in the PCM. Rather than write it all out, though, I'm going to be lazy and wait for you to tell me which path we need to investigate.
well its sunday about 11;28 am and testing the ram.
Old Apr 17, 2016 | 11:54 AM
  #35
bunker's Avatar
bunker
Default ok test results are!
Excellent! We'll just go from there and see where it takes us. If it's the worst case scenario, I have a potential hack in mind that might be fun to try. Since it ain't my truck that gets blowed up if my hack is destructive.
Back before I got lazy I made my living coercing electrons.
looking at the relay socket from the drivers fender pin 85 (right) side 13.83V (center pin 87a 0 V) left 86 0.09 V there is 2 slots under pie center slot pin 87 pin 0 V bottom pin pin 30 13.98. xin to find the amp drain now
Old Apr 17, 2016 | 12:45 PM
  #36
bunker's Avatar
bunker
Default test update
ok here we go.
doing amp draw test, with the tranny relay in theres no drain. with relay jumped get 1.2 amp draw. when I remove the tranny fuse in the pdc,
and I didn't know this before but when I remove the oxygen ssr fuse it also drops (never did that before) and both 02 ssr`s are spanking new 2 months ago
Old Apr 17, 2016 | 01:05 PM
  #37
bunker's Avatar
bunker
I just did a pin 21 ohms test and im getting 15ohms from pin 21 to ground with battery disconnected or connected and relay in.
with tranny relay out still get 15ohms....
with relay in and pull tranny fuse still have 15 ohms
BUTTTT when I pull the 02 fuse is dropped to zero.
im corn fuzed
Old Apr 17, 2016 | 01:40 PM
  #38
O2 sensor heater circuits get their power thru the ASD relay.
Check for power at the coil with the ignition off. (it also gets power thru the ASD relay.)
Old Apr 17, 2016 | 03:08 PM
  #39
bunker's Avatar
bunker
Default will try
ill givera try I have washed the pulleys off with degreaser before and helped maybe 2 days. ill try scuffing them up
Old Apr 17, 2016 | 06:00 PM
  #40
UnregisteredUser's Avatar
UnregisteredUser
I'm very simple minded and get confused if I try to understand two problems at once, so:
Maybe I missed it: Didja measure between pins 85 and 86 with the voltmeter? If you did and saw battery voltage with the engine running, let's stuff a known good relay into that socket, clear the DTC's, and see what happens after starting 'er up.
