What will gear lube in Transfer Case do?
![Unhappy](https://dodgeforum.com/forum/images/icons/icon9.gif)
So I had the infamous metallic grinding when 4-wheel is engaged. It gets louder when you accelerate. I had checked my hubs, my forward U-Joints and Pinion bearing. I found out my front output shaft bearing was shot. The shaft would also slide forward and backward towards the bumpers about an inch. I had almost 2 inches of slop when rotating my front drive line with a loud bang once it engaged. I recognized it was my chain. I believe the output shaft issue is related to the Chain. I have all my parts, seals and waiting on the chain. It is torn apart and only found metal flaking from the chain. No chunks, good sign. The rear output shaft is nice, smooth, tight and right. ![Icon Hunter](https://dodgeforum.com/forum/images/smilies/icon_hunter.gif)
Now to my question. When I drained my fluid, it was foamy greenish-brown. My son came over and made the comment that it looks like ?90 weight? Gear lube. I think he is right. If this assumption is correct, what would gear lube do to a transfer case?![Confused](https://dodgeforum.com/forum/images/smilies/confused.gif)
I don't think the previous owner used 4-wheel because the vacuum lines were disconnected. I have not used it because of the metallic grinding.
![Icon Chickendance](https://dodgeforum.com/forum/images/smilies/icon_chickendance.gif)
The condition of my front output shaft bearing is gone. It rolls smoothly; there is a specific spot though that about every two to four rotations it definitely grabs. The front shafts pilot bearing rolls smooth, but the pins slide back and fourth in the race. That one is gone too.
My rear output shaft rolls smooth, the ***** are on the loose end of snug within the race's. These probably have a couple thousand miles I'm guesstimating...
![Icon Pirate](https://dodgeforum.com/forum/images/smilies/icon_pirate.gif)
Is there a way to determine the input shaft bearings condition without separating it from the transmission? Or do you think it might be safe in the blast radius of the bearing grenade?
Finally, can the Oil be detrimental to the seals and nylon pieces in the main shaft assembly?
If you have the t-case apart already, just replace ALL the bearings.... and seals. You can get a kit that comes with everything you need.
Also, do a google search on "Transfer Case Saver". It replaces the snap-ring on the rear output shaft that likes to fall out, and munch up a bunch of parts on the rear output shaft.
The tail bearing is easily replaced, and don't mind tearing it apart again once I have the $30.00 to spare in a few months. Thanks for the heads up about the T-Case saver. I will install one when I open it back up to replace the bearings. For now, I will just purchase a new snap ring.
![Icon Nut](https://dodgeforum.com/forum/images/smilies/icon_nut.gif)
Trending Topics
When I went to O'riellys Auto, they told me it was ATF+4 and the volume was 1 quart+change. If your transfer case had a Power Take Off, it would be 2 quart+change. I double checked my Haynes manual and it depends on your T-Case. NV231 HD= 1.25Qt. NV241= 2.5qt NV241 HD= 3.25qt NV241 HD w/PTO= 4.5qt. I am a competent mechanic, I just never owned or worked on a pick up with 4-wheel drive, so I am in somewhat new territory.
HeyYou thank you. That really eases my mind. I was really concerned about my shaft assembly. From what I could tell, (Not removed) It felt smooth, right and tight. So keeping my fingers crossed.
