wiper an headlight issue
i recently just took body of 2000 ram 1500 an put it on my 99 24v, everything is working way it should but 2 things, if you turn on highbeams you loose headlights, an also when wipers are in delay mode they will stop wherever they want, anybody have any ideas???? i just replaced the multifuction switch an that did not help
Not to argue but the '96 and '97 rams are less than a year apart but the wiring is completely different. They went from supplying positive to various circuits to grounding those same circuits, to activate them.
Given the vagaries and whims of assorted manufacturers, anything is possible and should be taken into account.
Trending Topics
And...
That pesky CTM (central timer module) may be part of the problem too. Can you swap them (or is the donor gone)?
Unplug the CTM and see where the wipers want to stop. I think you should have no delay though.
The CTM is behind the lower dash panel where your right knee would hit it in an accident. There is a metal dash support (running vertically) and the CTM is attached to it.
no other issues at all, until tonight i was going thru making sure all grounds are good an disconnected battery to maybe hope to reset something, well now on the cluster my right turn signal stays lit up an when u do turn on right turn signal it blinks rapidly, i swapped the cabs 2 weeks ago just this week finally got time to try figuring that stuff out now its getting worse lol
