Fuel sync question
Fuel sync question
Google led me to a great write up on setting the fuel sync, but I have a question.
What specifically is different in setting this on a magnum, that I could point out to someone to ensure they do? In other words, I have mechanics that can do timing, etc, all day, but this write up seems to tell me magnums have an extra step, but I can't seem to follow it.
Being in central america, i don't want to just give them the write up in english. Thanks.
http://bionicdodge.com/Download/Cams...uel%20Sync.pdf
The fuel sync is usually set with scanners like the snap-on mt2500 scanners. But I came across this write up in Howe you could possible do it without these scan tools. You may even be able to do it yourself at home. It's in the first gen Dakotas, but I'm pretty sure it will still work for our rams. Personally I'd give it a try before I take it anywhere.
https://dodgeforum.com/forum/1st-gen...can-tools.html
in park and neutral the motor runs great, and when I hit the gas it reacts and sounds perfect. Once I'm in gear full throttle feels like half throttle, and I feel like I towing with a 4 cyl. I've had this issue for years.
I have one of the tuners here doing a tune, he said the scans and vacuum numbers look like a fuel issue and he suggests I test my fuel pressure under load, which I will be doing this weekend.
Is it possible for fuel pressure to drop while driving, but not while revving in neutral?
Trending Topics
I am having one of the guys here make a custom tune for me using an STC.
The more I read, the more I am excited to test the fuel pressure while driving. I'm having someone make a a fuel line that can reach my cab and hopefully I can test tomorrow. I will be happy as can be if the fuel pressure drops while driving.
