46re no low gear or od
Old 04-21-2017, 12:44 PM
Jordan Claycomb's Avatar
Jordan Claycomb
Jordan Claycomb is offline
Default 46re no low gear or od
Have two 1996 ram 1500s 5.9 2wd took one out and had it rebuilt on bench . Took new trans and put it in the other truck. Now I start out in 2nd in D. And when selector is in 1st it's not going into low gear. Plz help. Already replaced governor sensor twice. No codes. Plugs clean.
Old 04-21-2017, 04:25 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,197 Likes on 2,949 Posts
Verify that the shift linkage is adjusted properly. It that is ok, have a chat with your rebuilder.
Welcome to DF!
Old 04-21-2017, 09:08 PM
Jordan Claycomb
Default Crap
I just stripped a bunch of wire harness and I have power. But should it not engage in low regardless?
Old 04-22-2017, 08:21 AM
HeyYou is offline
If you put the lever all the way down, will it actually go into first gear?
Old 04-22-2017, 08:48 AM
Jordan Claycomb
No its definitey second gear when lever is down. There is some aluminum in pan. Thinking about dropping valve body aND putting a trans go in it. Replacing wire harness. My uncle is the brain hes done all this to his 98 4wd. Had two trans. Rebuilt by the same guy who just did mine. The builder is reputable. Has been bench building for 30 yrs
Old 04-22-2017, 09:12 AM
HeyYou is offline
Then before you go tearing into it, might wanna have a chat with him, and see what he suggests.
Old 04-22-2017, 09:28 AM
Jordan Claycomb
He thinks it's electrical. And I think he could probably rebuild that trans with a blind fold he's also ignorant to diagnosing it once it's in the vehicle. Taking valve body out will void my warranty. But I also think he's done his part and would be a waste of time taking it back to him. Do you agree I'm going in right Directon plus fixing some valves
Old 04-22-2017, 09:33 AM
dbbd1's Avatar
dbbd1
dbbd1 is offline
Bench rebuild? And you put it back in?
IMHO, I'd start with linkage and adjustments first. Unplug the 8-pin connector to the trans, you only have manual control (you will have to do ALL of the shifting). Shift to 1, does it still start in 2?
Old 04-22-2017, 09:39 AM
Jordan Claycomb
Yes he rebuilt it on a bench and I put it back in. And no I haven't tried that yet
Old 04-22-2017, 09:41 AM
Jordan Claycomb
But I bet it does start in 2nd unpluged. Trans and truck feel slow. Like it's fighting itself
