Front end knock
Other than a Borgeson steering box, the front end of my truck is stock. When I brake and turn left in residential neighbourhoods, I can hear a loud front end knock and feel it in the steering wheel. It's not the usual universal joint "clicking" when they fail. It's more of a pronounced "knock", usually just once. Like something is binding. It's also not the hub/bearings. I can also sometimes hear it just accelerating or braking in a straight line too (from or to a dead stop) but braking and turning left always makes it happen. Any ideas?
If you are planning to keep the truck awhile, here is a complete 3rd gen track bar conversion kit, which includes the bracket, an adjustable track bar and all of the needed hardware.
https://www.hellbentsteel.com/shop/p...bar-1994-2002/
![](https://dodgeforum.com/forum/images/df_new/buttons/edit.gif)
Luke's link should work fine if you are sure the track bar has never been replaced with an aftermarket unit.
I mention the other option, as it provides an adjustable track bar with poly bushings in each end along with a conversion bracket for the former ball joint end of the bar. The adjustable bar allows for fine tuning the centering of the front axle in the truck. I use a similar setup and have been highly pleased with it. It does cost a bit more, but if you are planning to keep your truck awhile, the added peace of mind for no more track bar issues is priceless.
Trending Topics
Up to you really. If you have the cash, the conversion is indeed an upgrade.
If that's the way the lukes link is designed to work, then sure. if it is a bandaid fix, then you will likely end up repeating the process again, and again. Still, you likely won't hit that magic number making the third gen style conversion financially sound..... You already HAVE the lukes link...... So, some shims are what? A couple bucks at most? Yeah, you could do that a lot, and never even come close to the cost of the conversion..... but, the conversion has the advantage of, install it once, and you will likely never need to touch it again.
