Ghost problem now starting prob
Old Jun 27, 2017 | 08:33 AM
Jerrit's Avatar
Jerrit
Question Ghost problem now starting prob
I have a 99 Cummins 3500 4x4 and I have been chasing a ghost. Codes left an right TPS, AIT, MAP AND PCM. well figured that out it was the batteries post. While that was going on you could hop in and it would bust over like normal now you have to wait on the chime for the seatbelt or dash.. any ideas
Old Jun 27, 2017 | 09:15 AM
Not sure I understand the problem. Did you do anything with the battery terminals?
Old Jun 27, 2017 | 10:44 AM
Jerrit's Avatar
Jerrit
[QUOTE=Jerrit;3347874]I have a 99 Cummins 3500 4x4 and I have been chasing a ghost. Codes left an right TPS, AIT, MAP AND PCM. well figured that out it was the batteries post. While that was going on you could hop in and it would bust over like normal now you have to wait on the chime for the seatbelt or dash.. any idea
I cleaned the post and ends to get better connection
Old Jun 27, 2017 | 11:10 AM
And you still have problems getting it to crank?
Old Jun 27, 2017 | 11:41 AM
Jerrit's Avatar
Jerrit
It's like the pcm hasn't told lift pump to turn on.. I have a fass pump when you hear the chime the pump cycles and it bust over. But till then it will crank till batteries are dead. I'm thanking loose wire some where but no clue. I'm going to try and disconnect both batteries and reset ect and pcm tonight and see what that does.. just looking for a little insight
Old Jun 27, 2017 | 11:56 AM
Is the lift pump controlled by a relay in the PDC? If it is, may wanna check that as well.
Old Jun 27, 2017 | 12:09 PM
Jerrit's Avatar
Jerrit
Yes has the relay that plugs in to the factory lift pump wiring to turn on relay. If you turn on key to roll up/down windows then turn off key the pump will run for about 15-30 sec then turn off. But if you turn key to run and leave on, in about 15-20 sec pump will cycle and it will start as soon as you pump the key ... PDC?
Old Jun 27, 2017 | 12:35 PM
PDC power distribution center. Black box behind battery on drivers side.
Is the PCM just not triggering the relay, or is the relay slow to react? That seems like a strange one. Swap out the relay, with another one, see if anything changes.
Old Jun 27, 2017 | 03:03 PM
Jerrit's Avatar
Jerrit
I will try that.. it has 2 relays 1- 30 amp that is for that fass pump then one in the PDC. The wiring to the pump has +/- wire with 30 amp fuse that ties in to the plug for the fass relay and plug for the factory pump then +/- to fass pump
Old Jun 28, 2017 | 08:48 PM
Jerrit's Avatar
Jerrit
Ok swap relays no change replaced battery terminals well now no pw to cab except start but won't do that any ideas no gauges no a.c. lights all dead
