Steering or Suspension problems
Old Aug 9, 2017 | 11:39 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Steering or Suspension problems
01 2500 5.9 with 1500 axles. I'm going to try to explain what I experience. Driving down the road I get wander and a shake (not death wobble) at about 45? And up also have lose steering (more lose them a girl with beads on bourbon street. If the truck is at a standstill and you turn the wheel either direction you get a clunk. I had a buddy turn the wheel and I inspected the driver's tie rod and track bar they tested good. Passenger has new tie rode an the steering box is new along with the tie rod that goes to that. I am stumped. It rides rough (I don't mind that) but you feel every bump to like the suspension has no travel.
Old Aug 10, 2017 | 06:37 AM
Moparite's Avatar
Moparite
Why? What about the wheel bearings ball joints?
Old Aug 10, 2017 | 08:26 AM
Which springs are on there?
Old Aug 10, 2017 | 09:38 AM
MoparFanatic21
Leafs are 1500 as they are 2.5" and 5 pack. Front I'm guessing by saying 1500 also
Old Aug 10, 2017 | 09:58 AM
Well, my 3/4 ton, with all of it's stiff-springed glory, rides like a truck..... I am intimately familiar with every little bump and pebble between my house, and the nearest town. I think the 98 rides stiffer than my 96 did. (and it was a 3/4 ton also.) Put a few thousand pounds in the bed though, and it rides like a Cadillac.
As for your steering...... Inspect EVERYTHING that moves. (and some stuff that doesn't.....) I have found that the 'stock replacement' steering boxes usually are worse off than what you are replacing. The 'reman' process only changes out bearings (sometimes) and seals. They rarely address the worn parts in them.
Also need to check the control arm bushings, and the track bar, (both ends.)
Old Aug 10, 2017 | 10:08 AM
MoparFanatic21
I accompanied the loose steering (dead from 12 to 3) to the steering box. Even when loaded the front end is to bumpy even for a truck. I inspected the control arm bushings and the track bar they are all good. I'll try to post a video of the "clunk"
Old Aug 10, 2017 | 10:14 AM
The clunk may be in the steering column, check out the Rock Solid Ram Steering Fix.
Old Aug 10, 2017 | 10:41 AM
MoparFanatic21
Do you have a link? Also instead of me steering another thread I have a question idk what year the computer is in my truck but it has a 96 engine harness and dash harness. I have the 01 engine harness and dash harness that this truck is supposed to have will they work with the commuter if it's a 96?
Old Aug 10, 2017 | 10:44 AM
Link.
No, it won't. A LOT changed in 98 with how the PCM communicates with the cluster. If you wanted to reinstall the 01 wiring, you would need a PCM that understands it.
Old Aug 10, 2017 | 10:50 AM
MoparFanatic21
Link.
Got a link on good reputable used pcms? Would I need to change the tranny harness? Basically I'm asking what do I need to buy to give me my 01 day back because I f***ing hate this 96 cup holders 😂
