Multiple misfire codes & catalytic converter not ready
I will try that tomorrow and see what the truck runs. Another question for you when we had it tested for emissions it told me that the O2 sensor and the catalytic converter are not ready. Is that something that just takes time since they're both new or is there a problem there?
We get the codes to clear for the test today but,it still failed because the o2 sensors and cat still say not ready. Do we need to drive the truck in order to get the cat and o2''s to become ready or can we just start it, let in warm up, shut in down and let in cool off and then warm it up all over again?
What codes are you getting(see link)? How long are you driving the truck before you get it inspected? I did mine years ago (new cat and both 02's) cleared codes and went to inspection the next week. No codes and passed emissions.
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
I've experienced multiple misfires because the connection at the pigtail for the cam sensor was full of dirt and grease. You might also inspect the cam sensor for cracks or other damage. It could have been damaged when the cap and rotor work was performed.
I will look into that thanks
