Cruise control
Old Feb 9, 2018 | 06:25 PM
Rammit82's Avatar
Rammit82
Switches are on the steering wheel. Don't think you can add them, have to find a steering wheel that has 'em. Clock spring is shortly behind the steering wheel. it's what allows the electrical controls in the steering wheel, (horn, cruise control....) to get their signals down to the part of the column that doesn't move. Brake switch is down on the bracket for the brake pedal.
I got all that figured out and I' sure I can get it all together but what about the PCM? What and where r the plugs I need for it? Thanks
Old Feb 9, 2018 | 07:58 PM
If the harness is already there, you won't have to do anything with the PCM.
Old Feb 9, 2018 | 08:57 PM
Rammit82's Avatar
Rammit82
ok awesome. Thanks. I'l keep y'all updated
Old Feb 9, 2018 | 09:03 PM
crazzywolfie's Avatar
crazzywolfie
I think our resident crazy is correct. Just need all the right parts installed, (I missed the brake switch in my list, and spelled 'battery' wrong.....) and it should just work.
after looking things up it looks like all the newer trucks use the same brake light switch so 1 less to worry about swapping out.
the rest of the parts should be easily acquired off a parts truck in the junk yard. you can get stuff like a clock spring new but always cost more money. best to just take the whole steering wheel and clock spring to make things simple. also once you pull the clock spring do not spin it at all. you can damage it if you do. under the hood you just need the. servo, throttle cable, vacuum lines and vacuum reservoir. best to try getting as much of the vacuum line as you can with the servo and vacuum reservoir just so you make sure to get the check valve for the vacuum reservoir. the vacuum reservoir keeps the cruise working good even when it don't have good vacuum. should all be plug and play tho
Old Feb 9, 2018 | 09:06 PM
Rammit82's Avatar
Rammit82
where does the reservoir go?
Old Feb 9, 2018 | 09:21 PM
crazzywolfie
the vacuum reservoir is located under the plastic cowel plenum cover at the base of the lower windshield
Old Feb 9, 2018 | 11:26 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Be warned these trucks had to small of a vacuum reservoir, and are know to have the "wild vents" issue along with loosing cruise speed when vacuum is low. Myself I have tried to fix this issue for 2 years, I've replaced all vacuum lines and check valves even put in a bigger reservoir. Now I finally got it fixed. What I did was installed a vacuum pump and got rid of the vacuum cruise control servo and installed an electric one so it takes one less thing off the vacuum system. Should be all plug and play. Up until 2008.5 Chrysler used one harness throughout the trucks. So even if you didn't have a certain option the plug was there. Good luck and I have a parts truck if you need any parts.
Old Feb 10, 2018 | 01:10 AM
Rammit82's Avatar
Rammit82
so what ur saying is I should install a Vaccum pump where and what kind? And an electric servo instead of a Vaccum fed one?
Old Feb 10, 2018 | 01:41 AM
MoparFanatic21
It varies by truck honestly. Some are fine but most aren't. Installing a vacuum pump will be good enough, I just went to an electric servo to see if it helped. Where I installed mine was right after it came out of the manifold I bought a T fitting and ran a hose with a check valve down to the pump. When the vacuum hit 14PSI the pump kicked on. Any pump (I got mine from eBay for $12) that can be switched to come on at a certain PSI is fine.
Old Feb 10, 2018 | 04:11 AM
crazzywolfie
are you sure your talking about a gas truck? you really don't even need the vacuum reservoir for cruise to work. it is just there to make the cruise to work smoothly when the engine may not be creating quite as much vacuum. also vacuum is measured in in-hg not psi. shouldn't need a vacuum pump on a gas truck tho. they are only needed for stuff with turbo that create boost and have no vacuum under boost.
