Cruise control
Old Feb 18, 2018 | 12:57 PM
  #51
Make sure the line to the vacuum reservoir is there as well. The res. hides under the cowl there.
Old Feb 18, 2018 | 12:58 PM
  #52
Rammit82's Avatar
Rammit82
So you have to take the vent cover off to get to it I'm assuming?
Old Feb 18, 2018 | 12:59 PM
  #53
Pretty much......
Old Feb 18, 2018 | 01:00 PM
  #54
Rammit82's Avatar
Rammit82
Ok I'll look into that next
Old Feb 20, 2018 | 04:54 PM
  #55
Rammit82's Avatar
Rammit82
Pretty much......
So if I'm getting no leaks with the Vaccum tester wouldn't the reservoir be fine?
Old Feb 20, 2018 | 08:23 PM
  #56
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Yep that is correct!
Old Feb 20, 2018 | 08:25 PM
  #57
Rammit82's Avatar
Rammit82
then what would the next step be? To pull the dash off and look at the doors and lines? Or is there an easier way?
Old Feb 21, 2018 | 01:59 AM
  #58
MoparFanatic21
Remember what I said before if all vacuum lines and check valves check good under the hood the only other vacuum lines are behind the dash that run to the HVAC box and to the switch.
Old Feb 21, 2018 | 08:01 AM
  #59
If you aren't getting any vacuum leaks, then leaks are not your problem. Lack of vacuum is. Maybe installing a larger reservoir would help.
