Moving Mechanical Fan Forward
Old Jul 19, 2018 | 01:46 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Moving Mechanical Fan Forward
I want to move the mechanical fan forward (towards the rad), and my idea is get some all thread and just using a wide nut attach it to the water pump and using the nut already on the fan to the all thread. Why would he do this you might ask, it's simple so I can get rid of the big ugly fan shroud and put in a 5" wide chrome one. What are your thoughts? Thought about e-fans but I tow with my truck and don't trust them.
Old Jul 19, 2018 | 05:12 PM
It would likely lead to accelerated wear on the water pump..... giving the pump shaft a longer lever arm for the fan to work on.... any (even minor) imbalance would be amplified the the longer shaft...... You would have little to no warning if it decided to come apart either...... it would just suddenly launch that fan into whatever happened to be nearby...... like, the radiator....... Keep in mind, the pump turns in a direction that makes the fan assembly want to screw itself on tighter....... using a nut as an adapter...... the spinning engine would be trying to UNSCREW that section......... (at the union from extension, to w/p)
I don't think you would care for the results.
Old Jul 19, 2018 | 07:13 PM
MoparFanatic21
I need to figure out how to get the fan forward then, because I want that ugly shroud gone . Didn't think of that good thinking! Also who doesn't like a fan in the radiator?
Old Jul 19, 2018 | 07:44 PM
Well, it tends to interfere with a vehicles utility......
Go electric. Grab a couple Ford Taurus fans. They move a LOT of air, are durable, and last just about forever.
Old Jul 19, 2018 | 07:46 PM
MoparFanatic21
I tow and heard about things about e-fans while towing.... I might upgrade to the V10 truck fan for better cooling. Nobody makes a wide enough chrome shroud to keep the fan in its place right now
Old Jul 19, 2018 | 08:42 PM
Could go to the V-10 radiator as well.
Old Jul 19, 2018 | 08:52 PM
MoparFanatic21
True but I have to figure out my brakes first. They completely went out the other day. So I had to turn in my emergency lights and siren (I'm a paramedic) to get people it off the way. No leaks and fluid kennel didn't change
Old Jul 19, 2018 | 08:56 PM
Blew the master cylinder?
Old Jul 19, 2018 | 08:59 PM
MoparFanatic21
I don't think because I now have brakes like before this incident happened not good, but average
Old Jul 19, 2018 | 09:26 PM
That's just weird. I wonder if whatever was stuck, cam unstuck...
Do you still have the load-sensing valve on the rear brakes? Or have you already bypassed that?
