crankshaft positioning sensor bold size- 1996 ram 5.2l
Old 07-28-2018, 01:55 PM
d000352's Avatar
d000352
d000352 is offline
Default crankshaft positioning sensor bold size- 1996 ram 5.2l
lost a bolt on crankshaft positioning sensor on my 1996 dodge ram 5.2L. know the head is 1/2 inch with a 1/4 allen fit, but need to know length, thread specs, etc.
Old 07-29-2018, 09:55 AM
Moparite's Avatar
Moparite
Moparite is offline
Cps uses two bolts not one. If you have the other one just get a replacement.
Old 07-29-2018, 03:34 PM
d000352's Avatar
d000352
d000352 is offline
was hoping not to pull that one off, as it is difficult to do so........
Old 07-29-2018, 06:23 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
MANUFACTURE'S PART NUMBER: P5249557AB
Specifications:
Fastener Finish: Black Oxide
Fastener Material: Steel
Head Style: Hex
Underhead Length (in.): 2.25
Washer Included: Yes
Thread Size (in.): 3/4-16
Straight from the parts book.
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
Whip out your arm with three elbows.......
They are allen head as well, use an allen socket on the one closest to the trans dipstick tube.
MoparFanatic21
I gave him the size and everything
Old 07-29-2018, 06:27 PM
HeyYou is offline
Yeah, I think I posted seconds after you did..... that wasn't there when I started.
Old 07-29-2018, 11:45 PM
MoparFanatic21
Exact same time to be exact
Old 07-30-2018, 10:29 AM
Moparite's Avatar
Moparite
Moparite is offline
Might want to check the # again.
Old 07-30-2018, 02:47 PM
MoparFanatic21
That's out of the 96 parts manual. I googled the bolt to and found that same info. Could be wrong (I thought they were 1/2) but I did the best I could without actually pulling my bolts.
Quick Reply: crankshaft positioning sensor bold size- 1996 ram 5.2l
