2nd gen performance
I might look into this just for the fact of a cleaner engine bay. I also am going to add a helper fan to the front of the A/C condensor for when you are sitting still.
Thanks man,
I'm interested for my frankenvan rather than my truck... It has oversized AC condenser and compressor to support cooling in the back and I just added another, larger transmission cooler when I converted it to 4wd. Between the added weight from the conversion and plating the frame, additional drive train load, heat from a higher stall converter, etc... I'm looking for additional heat removal - especially for times of higher demand / lower speed... (summer offroad exploring in the woods / mountains, and deep sand on the north Carolina Beaches).
I'm also thinking that removing the fan might open up an easy spot to add a v-belt pulley to drive a compressor for onboard air...
Thanks man,
I used an LS1 camaro dual fan. It fit really well. https://dodgeforum.com/forum/2nd-gen...r-special.html
That in itself makes e-fan worth it but I also have the TCP fan shroud, did the efans a while back... and e-fans ended up being one of my favorite upgrades. After all the forum e-fan bashing, I went in really skeptical. Best nothing I ever felt... Kind of like my air intake. Surprised me how much difference it did make.
Coincidentally I am currently awaiting a few eBay deliveries of a stock diameter serpentine alternator pulley and steel 6.31" V-Groove pulley supposedly off a lawn mower along with York ER210R, tank and other assorted doodads. I decided to make a nice pulley for myself I figure will put me in the 6-7cfm @ idle range. All this because I recently found a mounting bracket kit for sale on another forum which is also on it's way.
The Yorks output varies based on rotational speed. Within rotational speed limit of 6k, more rotational speed increases output. At max RPM's of 6k at it would be putting out over 10CFM at working load. All you have to do to pump up output is increase rotational speed. My custom pulley will allow for more air capacity than I'll ever use. I probably wouldn't even need the 3 gallon tank I ordered. With the Kilby overdrive pulley tests show you can expect around 3.2cfm at idle. My custom pulley should double that and then some, at 6.31" in diameter, and mine will have the benefit of not over driving the alternatorsince I'm using an oem serpentine pulley.
Per my research there isn't an electric, piston driven pump system that can hold a candle to those numbers at load. Even the dual piston ARB would never keep up with those numbers. They all have greatly reduced output at higher pressure you'd be running air tools at.
For example the high output ExtremeAire is only rated for 1,5cfm at 90psi. That won't run any air tools without a huge storage tank and waiting around all the time to refill it. The York keeps on putting out whatever it puts out, right up to working load limit.
Then there is the heat problem. Electric motors hate heat. Since I plan to mount my pump under the hood where it will get heat soaked by the engine, I didn't want to spend over $500 for the ARB, have reduced output capacity and system life compared with a properly designed engine driven system.
The biggest downside to engine driven system in my opinion is that I'm going to be forced to install the coelescing oil collection filter and oil return system and the fact you have to be careful about max rpm's These trade-offs seem worth it to me for the extra air capacity and longer system life expectancy.
yeah... I was thinking more like spending $100 or less on the on-board air setup (probably only need buy the compressor)... then simply bolting a v-belt pulley right where the fan bolts on now and making a mount for the compressor that would line up and include belt tension adjustment... Note that I have all sorts of pieces, parts, piping, fittings, steel and aluminum stock, lathe, mill, welders, etc... a spare pressure switch / controller and an extra 5 gal tank to mount underneath, then plumb for air fittings inside the rear doors.
Interesting re ls1 camaro electric fan... I may even have one from my C5 laying around... if not, I know where I can get one easily...
