Brake lights, turn signals
Do the front turn signals work ? The circuits for rear brake and turn signal are separate before the turn signal switch, and you have the third brake light working so look after the turn signal switch. There should be a connector along the left frame rail near the cowl area. Check if you get a signal there on pin 10 and 13.
Trending Topics
Although you said you already checked/replaced the fuses check them with a test light or something. You should have power at fuse C in the PDC and fuses 20 and 6 (with ignition on) in the fuse block at the dash. The fuse box also has the two round flasher relays, there should be power at the right pin.
