5.9 head to block tolerance
Old Jan 29, 2019 | 06:28 PM
99DR's Avatar
99DR
Default 5.9 head to block tolerance
can someone tell me the spec for the cylinder head to block tolerance for a 5.9 Magnum?
Old Jan 29, 2019 | 08:44 PM
Erm, they bolt together, with a head gasket..... there isn't any clearance. There are various thickness head gaskets though. What is it you are trying to do?
Old Jan 29, 2019 | 08:57 PM
99DR's Avatar
99DR
Each head eld has a straightness tolerance. I have to change a head gasket for the third time. I want to measure the straightness of the head and deck before I put it back together. Something is not right. I’ve been doing head gaskets for 40 years and have never had a situation like this.
Old Jan 29, 2019 | 09:47 PM
AtomicDog's Avatar
AtomicDog
This should help. https://www.enginebuildermag.com/201...straightening/
If you are having issues with getting a head gasket to seal, you might want to take the heads to a quality machine shop to have them checked/surfaced.
fj5gtx's Avatar
fj5gtx
I've seen big block mopar heads with a twist, causing that kind of issue. Not much experience with small blocks though. I'd take the head to your local good machine shop and let them check it out, they have the tools and experience to validate.
Old Jan 29, 2019 | 09:52 PM
99DR's Avatar
99DR
. I did that. I had them completely rebuilt at a local engine shop. That’s why I am asking about the tolerance. This head originally had a .004 gap. They shaved the head, and when I take it off, I want to measure it myself.
Old Jan 30, 2019 | 06:39 AM
Moparite's Avatar
Moparite
What exactly is the issue you are having?
Old Jan 30, 2019 | 09:56 AM
Do you have the tools to check it? Need a mechanics straight edge, which isn't cheap..... and then some feeler gauges. (which you can get just about anywhere.)
Old Jan 30, 2019 | 10:52 AM
AtomicDog's Avatar
AtomicDog
Please describe exactly what issues you're having - also, have you chased all of the head bolt threads in the block with a tap to ensure that the head bolts fully engage?
Old Jan 31, 2019 | 08:26 AM
99DR's Avatar
99DR
Yeah, I’ve got all of that sort of stuff.
