So I've decided to replace the plenum gasket while I have it apart(Fel-Pro gasket is only $13). You mentioned using shorter bolts. I'm assuming that you mean replacing the plenum cover bolts. Where can I get em? Standard hardware from Ace?
Yes the plenum cover bolts. Yeah uppi can get them there I use grade 8
Dumb design from the factory, you are right . It might work but I would advise against it. You only want to do this job once :b
Agreed...do it once. However, if the plenum hasn't already been changed(by previous owner, doubtful since it has ridiculously low miles for a 99), I'll be back in it within the next year or so.
Just so I'm clear on this, if the plenum cover bolts in the Dorman lit are the same length as those that come out of it, the new ones are too long. Correct?
