Fuel injector replacement tools needed
Old 08-06-2019, 03:02 PM
99CubbyBlue1500's Avatar
99CubbyBlue1500
99CubbyBlue1500 is offline
Default Fuel injector replacement tools needed
99 1500 5.2
I'm changing my fuel injectors tomorrow afternoon. I read a post on dodgeinfo.com that indicated that I would need a set of standard wrenches. My tools were stolen a few months ago, so I'm rebuilding my collection, and don't yet have standard wrenches. In looking at the job(fuel rails, etc)I can't tell where they'll be needed. Anyone know what I'd need them for?
Also, anyone know what the torque specs are for the fuel rail mounting bolts?
Old 08-06-2019, 05:26 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Originally Posted by 99CubbyBlue1500
99 1500 5.2
Need the standard wrenches for the fuel rail mounting bolts. And fuel rail disconnect tool for the lines
Old 08-06-2019, 05:28 PM
99CubbyBlue1500
Fuel rail disconnect tool? Where can I get one?
Old 08-06-2019, 05:31 PM
MoparFanatic21
Autozone or any parts store. You don't need it but it does make everything easier
Old 08-06-2019, 05:32 PM
99CubbyBlue1500
Will this work?
Old 08-06-2019, 05:38 PM
99CubbyBlue1500
I only saw 1 fuel line. It's on the driver's side rail. There's a rubber hose that goes from the driver's side rail to the passenger side rail. Looked to me like the fuel is supplied to the drivers side rail and goes through the rubber hose to the passenger side rail. Am I correct in this?
Old 08-06-2019, 06:39 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,385 Likes on 3,125 Posts
Correct. And that center tube does NOT come off.
Old 08-06-2019, 07:39 PM
MoparFanatic21
The main fuel line going into the rail on the left side. I've seen it where if it isn't disconnected it can crank (mostly on old lines)
Old 08-07-2019, 11:45 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
I believe you will need 13mm and possibly10mm sockets, a couple of extensions and a ratchet to remove the fuel rails to get at the injectors.
Old 08-07-2019, 03:09 PM
99CubbyBlue1500
Left(drivers)side showing what I believe is the fuel line going into the rail(just below the white electrical connector.
Left(drivers)side showing the fuel line into the left rail and the rubber hose connecting the left and right rails.
Right(passenger)side rail. Don't see any lines except for the rubber hose coming from the left side rail.
Is the one that you say does NOT come off the fuel line in the middle of the left(drivers)side rail? If so, where is/are the fuel line(s)? If not, where is the one that doesn't come off?
Thank you so much for your help so far.
Quick Reply: Fuel injector replacement tools needed
