Engine randomly cuts out, lights stay on
Old Nov 24, 2019 | 12:29 AM
potentshadow's Avatar
potentshadow
Default Engine randomly cuts out, lights stay on
Hey guys,
Long time no post, suppose that’s a good thing though right? Lol.
Truck has been running great for months thanks to everyone’s help.
Today on my way home from work driving about 30MPH my trucks engine cut off. I didn’t even notice it, until I pressed the pedal and nothing happened. All the lights remained on and I lost power steering. Put the truck in park and shut it off. Immediately tried to turn turn it over and it would crank but would not fire up. Interestingly enough if I waited about 1-2 minutes it would fire back up.
Sat for a couple of moments and tried to do a little research. Checked my battery connections and my alt connections. Alt is a reman from autozone I have had for the last 4 months or so. This just happened today and it happened twice within 15 minutes of each other. Thankfully I was able to make it home.
Truck is a 1998 ram 1500 5.2L 2WD
I have a new distributor cap, plugs, wires, rotor.
Has anyone ever seen this before?
Old Nov 24, 2019 | 07:52 AM
Moparite's Avatar
Moparite
If the engine died like shutting off the key i would suspect the crank sensor.
Old Nov 24, 2019 | 08:17 AM
Yeah, something is getting hot, and failing. Those are always fun to find...... When it won't start, check for spark, see what ya get.
Old Nov 24, 2019 | 10:56 AM
potentshadow
it’s probably worth noting I have a crappy autozone CPS (HeyYou gonna kill me) but it was supposed to only be temporary and I was gonna get a Mopar unit. So that damn sensor can even stop your truck while driving? I hate that thing.
HeyYou I am going to look into the spark and see what I can find. I think they make an easy tool to check.
Old Nov 24, 2019 | 11:39 AM
Torxhead's Avatar
Torxhead
I would think the pcm would have sent out a code indicating an issue, but sometimes it takes awhile for that to happen, good luck.
Old Nov 24, 2019 | 11:58 AM
potentshadow
no codes yet
Old Nov 25, 2019 | 08:31 AM
The PCM doesn't always get clued in to what is happening..... I have no idea what logic it uses to determine if a sensor isn't working properly. I am not sure that it uses any logic at all......
Old Nov 25, 2019 | 02:55 PM
potentshadow
Hey HeyYou!! Well y’all must have been my luck because today it did twice On my way to work, on the second time I finally got a CEL! Ran the codes and here they are:
P1391 intermittent loss of CMP or CKP sensor signals
P1682 charging system voltage to low
P0320 ignition engine speed input circuit
battery was not being drained when the truck was going so I don’t think it’s the alt. I guess it could be bad though?
Not really sure what the top and bottom codes are. I have a feeling it’s the CPS. (Is that was CMP and CKP are?)
As I mentioned I have a crappy duralast or whatever autozones garbage is.
Old Nov 25, 2019 | 03:57 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
CMP = Camshaft Position Sensor
CKS = Crankshaft Position Sensor
Old Nov 25, 2019 | 06:22 PM
Moparite's Avatar
Moparite
Where did you get the meaning of that code?
P0320 No Crank Reference Signal at PCM
