Hydroboost conversion ABS question
My power steering pump is going out on my 99 v10 4x4. I have a parts truck (2000 v10 2wd) with a hydroboost set up on it. I have decided I want to install the hydroboost system on my 99. Most everything looks like it will bolt strait up. My question is about the ABS module. The module on the 2000 is way different than the one on my 99. There are also only 2 brake lines on the 99 sending juice to the brakes from the ABS fuster cluck epicenter where as on the 2000 there are 3 lines. I have not yet crawled under the 2000 to see where the extra line goes.
So why are the 2 modules so different and do I need to install the one from the 2000 on to my 99? I have heard that when you swap ABS modules that the ECM sees the different vin number and the ABS light comes on but I have never seen it. In fact I swapped an ABS mod a while back from a 99 1500 and put it on an 01 1500 and my issue with that was resolved with no problems but I realize this is different situation.
Thanks for any help!
Grab the pump, lines, and hydraboost unit from the donor. Use the master cylinder currently on your truck, and leave everything else as is. No need to mess with anything else, all you are doing is changing the method of 'power' for the brakes. I love hydraboost.
Wish I had it on my truck.
That was my thought too, being electric I didn't think it would pump all the time...... Toggle switch lol.
But, you already have power steering. Hydraboost uses the same pump, just some additional plumbing.
Why would you want a hydroboost on a gas truck? A vacuum booster is simple and more reliable, a hydroboost makes sense on a diesel since diesels don't produce vacuum like a gas engine does. Putting one on a gas truck just adds extra complications, GM uses hydroboost on a lot of their gas trucks and they always have issues with them leaking and needing replaced, they aren't cheap either.
Trending Topics
