46re trans issues?
Old Feb 22, 2020 | 04:05 PM
  #81
I wouldn't be surprised if the new valve body didn't solve your issues. Just make sure it is for the correct year.
Old Feb 22, 2020 | 04:50 PM
  #82
Sheldon Fuller's Avatar
Sheldon Fuller
if it won’t solve it what else might it be?
Old Feb 22, 2020 | 04:51 PM
  #83
Sheldon Fuller
also the new valve body isn’t the same year, it came from a 2wd 46re that I think was a different year I’m pretty sure, it did the same thing in the old trans
Old Feb 22, 2020 | 04:53 PM
  #84
You re-used the valve body from the old trans, in the rebuilt feller, right? If that's the case, and the problem remains the same, replace it. Get another one.
Old Feb 22, 2020 | 04:56 PM
  #85
Sheldon Fuller
ok so it’s like this. I messed up the original trans. Took it out. Bought another one to put in it. It only had first and reverse and if it caught second it wouldn’t doen shift. So I took the stock trans and rebuilt it. Put it back in but put the valve body from the first and reverse trans that wouldn’t downshift and put it in the rebuilt one. So that’s why I believe it’s not downshifting.
Old Feb 22, 2020 | 05:00 PM
  #86
Still have the original valve body??? Might be interesting to clean that one up, install it, and see what happens.
Old Feb 22, 2020 | 05:01 PM
  #87
Sheldon Fuller
the old ones shot, it’s the one with the messed up shifter ball i done sold it to a guy for parts. I can get a new rebuilt one for $50
Old Feb 22, 2020 | 05:02 PM
  #88
Sounds like a plan. 50 bucks is a LOT cheaper than I expected them to be.
Old Feb 22, 2020 | 05:39 PM
  #89
Sheldon Fuller
yea new ones are 10 times that, the reason I’m getting it so cheap is because it’s the same guy I got the tail shaft from. He had completely rebuilt the trans and when he went to put it back in he broke the entire top of the bell housing off using impacts. So he’s just fed up with it. That’s how I got an entire rebuilt tailshaft for $50 as well.
Old Feb 25, 2020 | 02:23 PM
  #90
Sheldon Fuller
Ok so the plot definitely thickens, yesterday I dropped my pan and valve body to replace valve body and find this on the magnet.... what in the world is this. I can also say that the arm that goes to my low reverse band was really loose and out of spec, all though I still had reverse...
