Transmission Swap
Old Sep 6, 2020 | 07:19 PM
ThatRedRam's Avatar
ThatRedRam
Default Transmission Swap
I have 95 dodge ram 1500 318. I bought a truck that has the 360 and a nv4500 trans. Im swapping the motor and wanting to swap the transmission but what all would i have to do to swap it from auto to manual?
Old Sep 6, 2020 | 07:34 PM
ThatRedRam's Avatar
ThatRedRam
Do i have to swap anything with the transfer case?
Old Sep 6, 2020 | 07:51 PM
Is there a transfer case hanging off the end of the NV4500? If there is, use that one. If it's a 2wd trans, then I don't think it's gonna work......
Old Sep 7, 2020 | 07:34 AM
ThatRedRam's Avatar
ThatRedRam
Theyre both 4wd transmissions
Old Sep 7, 2020 | 08:32 AM
I think spline count on the output shaft is the same, (assuming both were gas engines) but I think the manual trans t-case had a deeper input 'hub', compared to the auto...... Something to check BEFORE you have it all in the truck.
Old Sep 7, 2020 | 09:03 AM
ThatRedRam's Avatar
ThatRedRam
I have a parts truck for this project so everything should be there to swap and shouldnt be to difficult. Swapping the motor and the trans along with the wiring.
Old Sep 7, 2020 | 09:15 AM
Wiring? Gonna do the whole underhood harness? (probably easiest.....) what year is the donor truck?
Old Sep 7, 2020 | 09:21 AM
ThatRedRam's Avatar
ThatRedRam
1995 same as mine. Mine is a 1995 Dodge 1500 318 5.2. Donor is 95 1500 360 5.9 with a nv4500. Mine has wiring issues so thats why im swapping the wiring through the cab and under the hood.Swapping the motor and trans to my truck
Old Sep 7, 2020 | 09:39 AM
Ok, that sounds like a good plan. Should go rather smoothly. If you can, take pics of the process, and post a build thread here.
Old Sep 7, 2020 | 01:44 PM
Spillage's Avatar
Spillage
...If you can, take pics of the process, and post a build thread here.
Probably what I should have done... instead I have a trickle of “what did you do today” posts.
