Help with misfire and bogging down
Old Sep 24, 2020 | 07:28 AM
  #101
Goshdarnram's Avatar
Goshdarnram
Wouldn’t the valve be stuck even if the truck was lifted though?
Old Sep 24, 2020 | 07:31 AM
  #102
It takes a LOT less effort to move the front tires when there isn't any weight on them.
  #103
Goshdarnram
Oh okay any way to test the valve in the box?
Old Sep 24, 2020 | 07:34 AM
  #104
Goshdarnram
What about air in the gearbox?
Old Sep 24, 2020 | 07:37 AM
  #105
Your fluid really didn't look like air in the system was a problem. (to clear and clean.) If there was air in it, it would be frothy, and you would actually SEE air bubbles in it. Since your steering is actually powered turning one direction, that implies the pump is doing it's job. But, no power at all when turning the other direction, regardless of where you start from, indicates that the valve that regulates fluid flow thru the steering box is NOT doing it's job. It is 'torque sensing', the harder you turn the steering wheel, the more assist you are supposed to get. You aren't getting any..... so, bad valve.
Old Sep 24, 2020 | 08:02 AM
  #106
Goshdarnram
Your probably right what are some good brands you would recommend going with and is it save to drive?
Old Sep 24, 2020 | 08:05 AM
  #107
Goshdarnram
I remember you spoke about a red one I’m trying to stay under the 300$ mark if possible
Old Sep 24, 2020 | 08:14 AM
  #108
I don't think you will find anything under 300 aside from the remans from the parts stores, and those are a real crapshoot...... more often than not, the box you get, is worse than the one you are replacing.
Redhead, Borgeson, and Bluetop are pretty much the best. None of them are cheap.....
Safe to drive? Since you are aware of the problem, I could only say "Kinda". If you find yourself in a situation where you need to turn sharply, quickly, in the direction the truck really doesn't want to turn, you will be screwed..... along with anyone else in your path. If you have something else to drive, leave the truck parked until you fix it.
Old Sep 24, 2020 | 08:17 AM
  #109
Goshdarnram
Will do I have a old Jeep I drive every now and again the red ones probably the one I will get I seen a few people say it’s the most common people having good luck wander how hard they are to change? Looks like a real pain but one step at a time with y’all’s help I’ve already fixed it up more then I thought I would for way cheaper thank y’all again I was really hoping it wasn’t the gearbox... but better to fix it right this time lol
Old Sep 24, 2020 | 08:25 AM
  #110
Goshdarnram
But I will keep you updated on how it goes when it gets here thank you all for the help hopefully we can get that done and we’ll be ready to ride
