Alarm going off all of a sudden
#32
I say nay, sir. As far as the CTM is concerned, the alarm is off, sir. What I am concerned and hope you know about is this...is the alarm off in the PCM? Is this the “no start condition” that the service manual refers to? How can I find out without a DRB tool. The pcm isn’t completely disabled because the obd2 still works(right?) and is this consistent with the “no start condition”? Thanks again, Lynn
#34
Without the vtss being activated on the replacement CTM there’s no way to trigger the vtss. Also, I am next to my 1999 ram when this is going down and there is no 3 minutes of alarm. The 98-99 service manual says there’s 15 minutes before the alarm shuts itself off and once that happens your horn will beep 3 times to alert you to that once you start the vehicle. I appreciate your help and hope u continue to do so, however I will also argue with a fence post. I will post a pic of the ignition lock and u tell me if it has skim on it or not. Thank you, Lynn
#35
I suppose they could be wrong but I found this link while doing a search and it confirms what I was afraid of all along. It isn’t the cost it’s the amount of time it takes. Thank you all for your time by the way and I will let you know what I end up doing. https://www.*********.com/attachment...cm-txt.163769/
#36
