Radio
Old Feb 29, 2024 | 06:52 PM
Was the old radio the Infinity version?
Old Mar 1, 2024 | 01:01 PM
J D GA's Avatar
J D GA
Default If, if, and if
Originally Posted by HOTPHOTO3
".....I purchased another Mopar Dodge OEM Radio but I can't get any Sound but faintly out of one Speaker on Driver side.. I can't figure out what is the problem ?
Anyone have any ideas ?
Thank You"
if you got no sound from the replacement radio, double check the fader & balance settings. Its output might be damaged or you have bad spkr connections....or 4 bad spkrs. in addition to the 1st radio that died.
If your truck was originally equipped w/Mopar radio, new 2-wire spkrs are PNP.
If originally equipped w/Infinity radio, its 4-wire speakers have external amps attached; therefore, new 2-wire spkrs are not PNP. An amp & crossover are required unless you replace the radio with one having an internal amp, say...27 or 52 watts x4 channels (your recent replacement?)
Recently, there was a similar thread from another forum member here with Infinity, though the OP hasn't provided a conclusion>>:
https://dodgeforum.com/forum/2nd-gen...ity-setup.html
Another member, Spillage (a "Record Breaker"), contributed the following to that thread:
This post covers the Infinity speaker wiring in my 98, and how I rewired aftermarket speakers.
Maybe that will help.
https://dodgeforum.com/forum/2nd-gen...ml#post2878048
Bryan
Have fun widdit!!
J D
