My V10 performance top end "swap"
Old 03-19-2021, 09:53 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,395 Likes on 3,135 Posts
Do you have a scanner that can read the misfire counters???? I would be interested to see which cylinders are misfiring.
  #62
Old 03-21-2021, 01:15 AM
adukart's Avatar
adukart
adukart is offline
My friend who is a tech used his, couldn't find any misfire data at all................ Also not getting any codes.
  #63
Old 03-21-2021, 09:58 AM
HeyYou is offline
Yeah. It seems the V-10 has issues with that. I had a dead miss on one cylinder, and it never set a code....... the scanner I had wouldn't read much in the way of data.... (waste of 50 bucks....) so, no idea if the PCM was noticing or not.
  #64
Old 03-22-2021, 11:14 PM
adukart's Avatar
adukart
adukart is offline
Well, think I found the problem. The only way this passed the smoke test was for the leak to be to the valley.
  #65
Old 03-23-2021, 09:22 AM
HeyYou is offline
Is that actually a bolt hole for the intake? Or just an alignment pin?
  #66
Old 03-23-2021, 10:43 AM
adukart's Avatar
adukart
adukart is offline
If you look above and just to the left of the bolt hole you can see the smaller hole for the alignment pin.
  #67
Old 03-23-2021, 11:27 AM
HeyYou is offline
Interesting. I suppose, with the mile long intake, that was pretty much a requirement to get things to align properly on assembly......
  #68
Old 03-25-2021, 10:13 PM
adukart's Avatar
adukart
adukart is offline
Well it still isn't fixed. It is improved, now it doesn't die when stopping at all but it is still mis-firing and popping if I don't let it stabilize the idle before taking back off. I can hear it mis-fire in the exhaust, its not the most consistent thing but kind of. I have poor throttle response and power. I pulled a couple plugs, seems lean to me. Both cyl 2 and 4 looked identical. I didn't pull any others yet. It is on a safe testing tune right now.
  #69
Old 03-26-2021, 06:52 AM
HeyYou is offline
Clogged injectors??
  #70
Old 03-26-2021, 10:46 AM
adukart's Avatar
adukart
adukart is offline
I don't know at this point. I picked up a spark tester and I am going to also do a compression check.
Quick Reply: My V10 performance top end "swap"
