My V10 performance top end "swap"
#41
on
07xx is a generic transmission OBDII code. 17xx would be Chrysler specific. If there are no other codes present, the book will point toward incorrect voltages, ie., bad connections, open circuits, short to voltage, short to ground, sensor resistance outside of the approx. 300-1200ohm range. Failing sensors can get wonky when hot it seems. Intermittent problems (yours won't set the MIL) sound like wiring.
Seems possible to monitor the speed sensor voltage the PCM sees with an analog VOM looking for small spikes a digital VOM can't display.
What happened with the varying idle voltage (flickering lights) and fuel pump pressure? Did the rail ever hold pressure?
I've no idea how to how to deal with an IAC issue, but physically restricting the orifice or maybe fooling the PCM with a small resistor might be a workaround.
That condenser/capacitor by the coils most certainly should exist, my '99 has one. That circuit, A142 is ASD relay power to the coils, injectors, and PCM. I'd be also curious to see what voltage the PCM is seeing at any given time, especially during malfunction. I read this thread from time to time because it's interesting, and you seem capable.
#42
Also thank you for the compliment. Where is your capacitor attached to? I forgot to document it and just have it attached to the coil mounting bracket bolt.
#43
So I did something unorthodox. I Disconnected the main vacuum port for the vents/cruise and plugged the line. No more stalling. The idle still drops to 500rpm and runs rough when coming to a stop and then picks back up to 650rpm where it should be. Still bogged a little with some occasional backfiring then took off. That's the best its ever felt when it takes off. Now I'm even more confused. I think I may have an issue with the new IAC, which Hey You eluded to already. However still something mysterious. I even took the top off the ignition wire track and made sure all the wires were separated to verify no crossfire.
#44
#45
#46
I keep forgetting the pressure sensor however I did do a couple things.
1: Improved smoke test. I made a plate to block off the throttle body opening. No smoke from any external leaks (yay I found and fixed all the broken lines). However there was smoke pouring out of the breather in about 5-10 secs. That concerns me.
2: I sent my datalog to the tuner. He said most likely I have a vacuum leak.
#47
#48
At a shop my friend works at. Used a professional pressurized smoke machine attached to the brake booster line. We blocked off the throttle body with a plate and smoke for 10mins. Only place it would come out is the breathers/oil fill. We clamped off the breather to the air box after smoke came out of if (air box was off).
#49
#50
