Suspension
Old 12-26-2020, 06:51 AM
O Hen's Avatar
O Hen
O Hen is offline
Default 2000 ram 1500 5.9 Laramie suspension
Extended sway bar links with 3" strut lift?
Old 12-26-2020, 09:31 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,275 Likes on 3,022 Posts
2nd gens don't have struts.
The following users liked this post:
jkeaton (12-26-2020)
Old 12-26-2020, 10:25 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Strut/shock/damper - some people use them interchangeably. On to topic:
I installed Maxx Links about four years ago and they seem to hold up pretty well. But they rusted almost immediately so be sure to paint them. I used these for up to 3" lifts:
https://suspensionmaxx.com/product/SMX-1223L
O Hen (12-27-2020)
Old 12-26-2020, 10:32 AM
HeyYou is offline
The newer trucks actually use struts though..... and we have zero information on what he is driving..... So, maybe he has them, maybe he doesn't.
O Hen (12-27-2020)
Old 12-26-2020, 06:48 PM
O Hen's Avatar
O Hen
O Hen is offline
The big spring. I put a spacer on top of it. Ordered extended shocks. Wandering about the sway links 👍
Old 12-26-2020, 06:55 PM
O Hen's Avatar
O Hen
O Hen is offline
Tires are leaning top out a bit. Hope the shocks help with that. Or maybe didn't seat the strut all the way? Needs shocks anyway, the others are stretched 100%
Old 12-26-2020, 07:58 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Too much eggnog, Hey? His truck is in the title of his first post.
O Hen (12-27-2020)
Old 12-26-2020, 07:59 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
If the tires are leaning out at the top then the ball joints are the cause, not the shocks.
O Hen (12-27-2020)
Old 12-26-2020, 08:15 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
I agree sounds like upper ball joint
O Hen (12-27-2020)
Old 12-26-2020, 08:18 PM
MoparFanatic21
Find out how much you need for the sway bar to be parallel to the ground and just search "x" sway bar links for 2001 Ram" "x" is the size you need.
O Hen (12-27-2020)
Quick Reply: Suspension
