As the WHEEL TURNS (or doesn't) continued steering saga
#71
#72
I thought the Spohn came with everything to? I guess it really comes down to what you like. I've seen things on Genos get highly marked up. I do know that it can be straight and clear everything. Another option is buy just the bracket, and used a factory 3rd gen bar.
#74
#75
#76
Finished the alignment (zero toe) and tightened everything down. Took her for a spin. Definitely tighter over bumps and steering is a bit less loose. Not amazing but much better.
I put the castor at top dead noon, toe to zero, and straightened the steering wheel. Hopefully it proves to drive well. I've only buzzed around town a little since it's 108 out.
Overall:
- definitely would never rebuild the track bar again. It's just too much hassle to get all the individual parts, remove paint, remove old bushings, etc. Next time will be a 3rd gen kit.
- Delphi TREs are nice quality and definitely the same size bars/threads as the moog. I ended up getting new MasterPro sleeves from oreillys which fit perfectly as well. The Delphi ends are flat bushings to prevent rollover. Hopefully they last longer than the moog crap.
- I also took the time to scrape the old paint and rust off the Skyjacker springs and repainted red with tractor enamel. Hopefully they remain red for awhile.
- This is the newest everything under the truck has ever been since 1999. The steering gear is four years old, pump is one year old, hoses 1 year old, new track bar and TREs. I'm crossing my fingers!
Overall:
#77
#79
I'll get some pics tomorrow. I was too worn out today. The heat here is unbearable and no AC. Been really bad.
It seemed to steer smoother, the power assist was different but I don't know how much better. Couldn't hear the pump cause the AC was cranked on high so who knows. When I left the driveway the steering wheel cocked at about 10 oclock so I had to do more adjusting. Kinda feels dead in a way but maybe it will settle in. More to come I'm sure.
Where do you have your caster bolts? Long time ago I read to put them top noon but I've tried forward and rearward and there doesn't seem to be a difference. I can't figure which way is positive or negative. I'm a musician, not an engineer. Thanks, guys.
#80
