Head upgrade
#43
Comp cam #20-604-9
that's what they recommended with level 1 ported EQ heads. Have the HV water pump, heavy duty fan clutch, Accel ignition system, 8.2mm high temp plugs, dropped the oil pump and screen today, replacing with HV should be in today. No sludge in this block on the top or the bottom. Just hope i get the rear main seal rite and the oil pan doesnt leak either. Have to get a harmonic balancer puller. Putting a double comp cam timing chain on it. I know i need hardened push rods but will the stock length be optimal considering the upgraded springs on the heads and better rocker arms I'm going to buy?
#44
For those that aren't aware, EQs are no longer "EQ" heads. The performance version everybody is thinking of is no longer available. Only EQs available now are stock replacements. Hughes even mentions this in the link shared earlier. The Indy heads were cast by EQ as well and being that they're no longer produced, the Indy's aren't either.
Also, injectors are a waste below 350 at the tire which you won't be anywhere near. Hughes is trying to make a buck. Stock are more than you need
#46
#48
#49
Edit: if you follow the IMM engines link and press HOME, that page completely disappears and is replaced with an LA aluminum import head page
