The main things are there’s a tube with suction coming from behind the carb block out and the closets connection to it I can find is this “T” connection of tubes with one side cut. The next thing is this black solenoid behind the drivers headlight. Is this the purge solenoid?
The highlighted part is the tube coming from the back of engine. The arrow is the “T” connection
Its most likely going to you speed control unit. And if you are hearing a whistle sound from the engine, Replace the intake manifold gasket if you have a V10 engine. This was a common problem.
so I actually found the source of the whistle it’s a tube coming from the top back side of the engine near the passenger valve cover when I cover the tube the engine stalls out and dies. Is this tube supposed to be left cut or is it supposed to attack to something else?
