Ac system giving trouble
#22
Yessir, I seen that on YOUTUBE but NEVER on a 94...AND there was always a DIMPLE or PINCH MARK... However, I will use the air compressor this a.m. and blow through it with about 50 lb of pressure both ways you know before I put my new accumulator that should come today. Every other piece except for the lines of course has been replaced with new except the evaporator I hope to God I don't have to change that. I think I'm going to take a piece of weed eater line and run up in that one tube and just see if I feel anything.
#23
Good morning, I blew through the system both directions at 50 lb then at 100 lb. Yes I cannot see that there is any type of obstructions. Of course the tubes are disconnected from the compressing unit it has the shipping block bolted back on it. Here is a question.
CAN I ADD SOME FLUID TO THE TUBE SUCH AS WATER AND BLOW SOME WATER THROUGH THE SYSTEM BECAUSE IT IS ONLY GOING THROUGH THE CONDENSER THE TUBE THE EVAPORATOR AND BACK OUT THE ACCUMULATOR?
Wait a min... Water won't come to the dryer of course... I'm going to remove the old accumulator / dryer and then blow water through it how about that?
#24
Okay here's the newest info... You can see a picture of the block and the lines that come off the top of the compressor and a picture of the old accumulator...THE BLOCK AND THE LINES ARE COMPLETELY CLEAR.. (the accumulator is clear but I have a new one).....
The second photo I have a line in my hand and in the background you can see the exit line of the evaporator... THE LINE I HAVE IN MY HAND GOES IN THE TOP OF THE CONDENSER... THE LINE AROUND THE FENDER COMES OFF THE BOTTOM OF THE CONDENSER INTO THE TOP OF THE EVAPORATOR.. THAT PART OF THE SYSTEM BLOWS FREELY WITH NO RESTRICTIONS BOTH WAYS. .. I did use water to purge that part of the system so I will blow it with air for an hour or so... I am in north Texas where it is hotter than blazes as well.... ANY THOUGHTS?
#26
No not without a major dismantle which I have already researched I have a new evaporator but that's the last thing I want to do however each piece of the system is taken apart I've broken every joint that can come apart I've removed the new evaporator and everything and have blown each line and each piece out with the air compressor at 50 to 100 lb including the evaporator which is still installed... Of course the new compressor it's still installed with the shipping cap put back on it. Everything is clear and I did find the orifice location. Now unless the orifice malfunctions under the pressure of the freon being in the system there is nothing that could be wrong that I can understand.
#27
Here is a photo of the completely disassemble system you'll notice the green disconnector that is for the orifice is... The dryer is new I just got it today never installed. All of these pieces except for the dryer has been purged with water to ensure no blockage. Purge both directions. I personally evaporator with water and a blowing it out every several minutes. These pieces on the ground have been blown out a number of times and setting in the Texas Sun. . My only question is could the orifice malfunction under the pressure of a charge?
#29
Okay okay understandable understandable I will show this to my AC tech when he comes back by today however 30 plus years on the system at 200,000 miles I mean it was worth changing anyway but explain this to me ... During the initial charging just jump the Hot side switch briefly? One second two second 10 seconds? With the motor running or not running? I know my check will probably know this but just in case.
#30
